hello,
can anyone link me the default configuration.yaml from aio install?
retard me overwrites it with the config yaml from my windows based HA with nothing on it…
thanks
hello,
thanks
Try this.
https://github.com/home-assistant/home-assistant/blob/dev/config/configuration.yaml.example
There is some extra stuff in there from what I remember from the default but it should be enough to get you going.
thanks, but what i need is the mqtt config from the default config.yaml since i have no idea what settings did the aio put in it…
IIRC the default was just mqtt:
More info here:
hi. what i’m looking for is the mqtt setting that the AIO set up…
finally found what i need in fabfile.py from the AIO git…
here’s the link in case anyone needs it
