Goal: Install HASS.io on Ubuntu 16.04 and then take down HASS.io on RPi3.
I’m half-way there, but there are some points of confusion.
HASS.io is running on Ubuntu in a Docker container. The configuration.yaml file looks a bit different than the one that is on my Pi3.
There’s no homeassistant:
section, and there’s a default_config:
section.
On the RPi3, I had to update the homeassistant:
section with various options, and then I also have a config:
section.
It seems some of the options that were in my old homeassistant:
section are taken care of through the new onboarding dialog when installing HASS.io for the first time, so I don’t know if adding the homeassistant:
section is still required?
The old config:
component that was on the Pi3… does it need to be there again? What does this default_config:
component do?
I’m trying to make sure I don’t screw things up.
