Default dashboard for specific user
I can see this has been mentioned before but could not see a solution .
Essentially I wish a logged in user via the app to only see a specific dashboard with no access to other dashboards. Thereby allowing effectively restricted access ( hence SWMBO not messing things up ) .
Is this possible ?
Much appreciated in advance.
I do not think that is possible, best you can do right now is to have all dashboards with conditional cards that show things only to certain users.
More detail
For example
I have a wall mounted iPad in the bathroom .
It would be great to restrict that to the bathroom music player and bathroom lighting - but nothing else .
Similar ‘ restrictions ‘ for kitchen etc …
Hope that’s added some clarity
Much appreciated. I will look into that !
you can add/remove visibility for individual users for each “view” of a dashboard for from the ‘visibility’ tab while editing your dashboard
Quickly looked at this .
So I could create a ‘bathroom ‘ user and use that as a conditional card for the dashboard ?
Making sure that particular iPad always logs in as ‘bathroom’ by default ?
That correct ?
If the iPad is in sleep mode and awaken how ( or can I ? ) default to bathroom user ?
I’m having the same issue. When I log in with a tablet, using a user (not set to administrator) it logs in at the default dashboard, which is not the one I need to use for that tablet. Is anybody having a solution?
