I am installing HA in docker on my Orange Pi (armbian), but when i try to use the default config (especially host mode network, doesn’t happen on bridge) i get an error like this
homeassistant | s6-rc: info: service s6rc-oneshot-runner: starting
homeassistant | s6-rc: info: service s6rc-oneshot-runner successfully started
homeassistant | s6-rc: info: service fix-attrs: starting
homeassistant | s6-rc: info: service fix-attrs successfully started
homeassistant | s6-rc: info: service legacy-cont-init: starting
homeassistant | s6-rc: info: service legacy-cont-init successfully started
homeassistant | s6-rc: info: service legacy-services: starting
homeassistant | services-up: info: copying legacy longrun home-assistant (no readiness notification)
homeassistant | s6-rc: info: service legacy-services successfully started
homeassistant | 2023-06-21 11:13:31.080 WARNING (MainThread) [zeroconf] Error with socket 14 (('192.168.0.157', 5353))): [Errno 1] Operation not permitted
homeassistant | Traceback (most recent call last):
homeassistant | File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 1196, in sendto
homeassistant | self._sock.sendto(data, addr)
homeassistant | PermissionError: [Errno 1] Operation not permitted
homeassistant | 2023-06-21 11:13:31.765 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 1] Operation not permitted, transport: <_SelectorDatagramTransport fd=19 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=19, family=2, type=2, proto=0, laddr=('0.0.0.0', 41293)>
homeassistant | 2023-06-21 11:13:31.769 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 1] Operation not permitted, transport: <_SelectorDatagramTransport fd=19 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=19, family=2, type=2, proto=0, laddr=('0.0.0.0', 41293)>
homeassistant | 2023-06-21 11:13:31.773 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 1] Operation not permitted, transport: <_SelectorDatagramTransport fd=23 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=23, family=2, type=2, proto=0, laddr=('0.0.0.0', 49149)>
My docker-compose.yml file
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- ./config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: host
