Default home zone
thanks i will give that a try
I can’t find the configuration > customizations page. Which configuration page is this?
I think that menu option is no longer available after updates. Need to use yaml
I am sorry I don’t understand the terminology. What is this UI you are mentioning Dashboard? What is the configuration do you mean settings? configuration.yaml? where is this customization? Thank you
That menu was removed a long time ago.
The solution you need is documented here
