Default light effect on turn on
I am trying to implement a default turn on state for some RGB LED strips.
I have some effects setup that I can access from the dashboard and work well.
I want to setup a default effect (Slow Random Colours) when the strips are turned on but having trouble with the on_turn_on action.
I have tried various combinations of code but cant get it to validate.
light:
  - platform: rgb
    red: red
    green: green
    blue: blue
    effects:
      - random:
          name: "Slow Random Colours"
          transition_length: 30s
          update_interval: 30s
      - random:
          name: "Fast Random Colours"
          transition_length: 4s
          update_interval: 5s
    on_turn_on:
     - random:
         update_interval: 5s
What is the error message?
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block mapping
  in "/config/esphome/RGB Feature Light.yaml", line 90, column 9:
expected <block end>, but found '<block mapping start>'
  in "/config/esphome/RGB Feature Light.yaml", line 91, column 10:
After your on_turn_on trigger you need to use the light_turn_on action to set the effect.
https://esphome.io/components/light/index.html#light-turn-on-action
    on_turn_on:
      - light_turn_on:
          effect: "Fast Random Colours"
Thanks, that solved my problem I appreciate the help.
Not being a programmer, some of the documentation isn’t always obvious.
Didn’t work straight away but noticed the typo.
light.turn_on
Thanks again.
An old post, but on the same topic: is there an easy way of setting a default colour/brightness etc after the initial turn on (eg ESPxxxx module reboot) only?
I’m successfully using on_turn_on to set colour and brightness. I would like to be able to turn the LED strip off/on from HA without altering settings but have a module boot-up default to a standard setting - on_turn_on appears to execute under both scenarios. Possibly there’s a lambda option but either there isn’t or I haven’t got the syntax correct.
On reboot you want on_boot:
Ah - thankyou, as simple as that! I searched everywhere under the light component options and tried complicated lambdas, but logically it’s part of the ESPxxxx core config not light control.
Code works now as expected.
