And because the ISS is showing on my Default Map I am unable to see those entities that are local to me in the NW of the UK when the ISS is anywhere but on top of me.
Is there a way to either
a) Remove the ISS from the default map but still show in the Map Card specific for tracking the ISS?
or if it is not possible
b) Remove the default MAP from the left-hand side?
Yes, I have the “default_config:” line in my configuration.yaml but I don’t want to break it either.
Can you tell me HOW to show the mobility line in the map card?
I have installed and configured satellite tracker custom component for ISS but what i can see is only the following:
