Default power state after power outtage
Hi
i have a gledopto led strip controller that after a power outage it powers on automatically.
in the zigbee2mqtt component i can see this two kind of message sent by device:
  • Received Zigbee message from ‘0x00124b001d3ac596’, type ‘readResponse’, cluster ‘genOnOff’, data ‘{“onOff”:1}’ from endpoint 11 with groupID 0
  • MQTT publish: topic ‘zigbee2mqtt/0x00124b001d3ac596/availability’, payload ‘online’
how i can set an automation that when this two message are sent then it power off the device?
thanks
Like this:
automation:
  alias: Keep it off
    - platform: state
      entity_id: light.your_light
      to: 'on'
    - service: light.turn_off
Assuming of course that Home Assistant runs through the outage…
Tank you but sometime the powerouttage Is faster than homeassistant update the state of the light to available to unavailable…
