As I understand this should already been implemented but I have not been able to get it working. How can we add the limits to the default sensor card? It says from the documentation
Visual editor is not supported for this configuration:
* Key 'limits' is not expected or not supported by the visual editor.
You can still edit your config in YAML.
Oh I think I understand it correctly now. It affects the card view but not when I click into the card to view the graph. That would show the full range of the sensor instead of the limits is that correct?
