Excellent work gang. I have a request. When I restart HA default items light dark screen and default dashboard is not saved and has to be reset every time. Could you fix to allow these settings to save these option and restart as such.
The theme is saved as long as you aren’t clearing browser settings or using incognito mode. Also, the settings are based on a ‘per browser’ method so signing in elsewhere will require setting the theme again for that browser, but only once if the above is complied with.
