The weather report has changed now which means it reports at 02:00, 08:00 and not 01:00 and 07:00 as last week.
But instead of just patching it, I figure I can do better and get the weather at both 07:00 and 08:00 (perhaps 09:00, and 06:00 just to be sure).
But the issue is that I can’t use default value when the attribute is missing.
The template is getting mondays weather report on friday, that is why the report is not detailed enough to have all hours.
{%- set dt2 = ((today_at("07:00")+timedelta(days = 7-now().weekday()))| string)[0:16] -%}
{%- set aa = state_attr('sensor.smhi_hourly', 'hourly')[dt2]['nederbord'] | float(0) %}
{%- if aa > 1 -%}
True
{% else %}
False
{%- endif -%}
above is the simplified version, but what I want is to check if the attribute is there then use it, if not then either return 0 or somehow if attribute missing then
The float(0) does not seem to make any difference, when I run the automation it reports Error rendering data template: UndefinedError: "dict object" has no attribute '2024-04-01 07:00'
And that is true but shouldn’t aa
have become 0.0
