Default view on timeout
This blueprint makes it easy to have a Lovelace interface which returns to a default view after a timeout.
Requirements:
browser_mod by Thomas Lovén (https://github.com/thomasloven/hass-browser_mod)
Home Assistant minimum version 2012.2.0.
Use:
First you must find the entity of the device to control. This is sadly not as easy as it could/should be, since Blueprints does not offer the possibility to sort entites by their attribute. It gets a little easier if you specify a alias to the deviceID (https://github.com/thomasloven/hass-browser_mod#aliases)
Secondly, you must the default path.
Lastly you will need to select a timeout in seconds before the device navigates back to the default view.
The Blueprint
blueprint:
name: Default Lovelace view
description: |
# Default Lovelace view
This blueprint makes it easy to have a Lovelave interface which returns to a default view after a timeout.
## Requirements:
+ browser_mod by Thomas Lovén (https://github.com/thomasloven/hass-browser_mod)
+ Home Assistant v. 2021.2.0 as minimum (text selector)
## Use:
Find you must find the entity of the device to control. This is sadly not as easy as it could/should be, since Blueprints does not offer the possibility to sort entites by their attribute.
Second, you must enter the default path.
source_url: https://github.com/J-Lindvig/HomeAssistant/blob/master/blueprints/automation/J-Lindvig/default_view.yaml
domain: automation
input:
device:
name: The device to operate
description: Choose the device you with to have a default view
selector:
entity:
domain: sensor
path_default:
description: Path of the default view ex. '/lovelace/0'
default: "/lovelace/0"
selector:
text:
timeout:
description: After this time out return to default view
default: 30
selector:
number:
min: 10
max: 300
step: 5
unit_of_measurement: seconds
mode: restart
max_exceeded: silent
variables:
device: !input device
path_default: !input path_default
timeout: !input timeout
- platform: state
entity_id: !input device
attribute: path
- delay: "{{ timeout }}"
- service: browser_mod.navigate
deviceID: "{{ state_attr(device, 'deviceID') }}"
navigation_path: "{{ path_default }}"
