Define a trigger id in a button (card) that triggers a specific automation part
Hi
I created a button on my dashboard that triggers a specific automation, but I’ve got like 6 automations that I want to setup the same way. Is there a smart way to reduce the amount of automations?
I would like to put all of them in just one automation,
and then set a trigger ID in the button card (for instance), that triggers the correct automation part. Is that possible?
show_name: true
show_icon: true
type: button
tap_action:
  action: perform-action
  perform_action: automation.trigger
    entity_id: automation.backup
    skip_condition: true
What you are describing is usually what we call a script.
A script is manually triggered.
An automation runs automatic
If it’s a script, then you can pass parameters and use a Choose based on the parameter to decide which actions to take.
hmm I already have those automations in place, can be time consuming to convert everything to a script which I’m not experienced in.
this could also be a solution right? I created an input_boolean (so for each button).
then I can define the button like this, to trigger the boolean.
show_name: true
show_icon: true
type: button
tap_action:
  perform_action: input_boolean.toggle
    entity_id: input_boolean.test
and the automation looks like this, which executes the automation part that belongs to the button.
description: ""
mode: single
  - platform: state
    entity_id:
      - input_boolean.test
    to: "on"
condition: []
  - if:
      - condition: trigger
        id:
          - "1"
    then: []
I can include the other automations like this easily.
thoughts?
that way I reduce the amount of automations but with an increase of helpers :stuck_out_tongue: not sure if this is the cleanest way.
Sure, just like using a sledgehammer is a solution to cracking nuts. It is a solution but not the correct one.
Use the correct tool for the job.
A script will not require you to create any input booleans. They are easy to learn, they are just like automations without triggers.
Converting an automation to a script is really just a copy paste from action to sequence.
All the time you spend on creating the booleans will be better spent learning scripts.
