I have a script that outputs a json content:
"timestamp": 1626357199,
"data": {
"classic": {
"name": "Classic Unit Type",
"value": 150,
"unit": ""
"rev": {
"name": "Classic PCB Revision",
"value": 4,
"unit": ""
"firmdate": {
"name": "Firmware Date",
"value": "2015-11-23",
"unit": ""
"firmver": {
"name": "Firmware Version",
"value": 2079,
"unit": ""
"commver": {
"name": "Revision of the communications code stack",
"value": 2073,
"unit": ""
"uptimeh": {
"name": "Uptime hours",
"value": 14,
"unit": "hours"
"uptime": {
"name": "Uptime days",
"value": 0.58,
"unit": "days"
"plifetime": {
"name": "Lifetime kWh",
"value": 10086.9,
"unit": "kWh"
"ptoday": {
"name": "kWh Today",
"value": "4.4",
"unit": "kWh"
"ftoday": {
"name": "Float Time Today",
"value": "5907",
"unit": "seconds"
"cstate": {
"name": "Charge Stage Raw",
"value": 5,
"unit": ""
"cstageword": {
"name": "Charge Stage",
"value": "Float",
"unit": ""
"cstagelin": {
"name": "Charge Stage Lin",
"value": 5,
"unit": ""
"state": {
"name": "State Raw",
"value": 3,
"unit": ""
"stateword": {
"name": "State",
"value": "Active",
"unit": ""
"restingreason": {
"name": "Reason for resting",
"value": "5",
"unit": ""
"restingreasonword": {
"value": "Too low of power out and Vbatt below set point for > 90 seconds",
"unit": ""
"restingreasonwordshort": {
"value": "Low Light",
"unit": ""
"infoflags": {
"name": "Info Flags",
"value": 2986356740,
"unit": ""
"tbat": {
"name": "Battery Temp",
"value": 25.2,
"unit": "\u00b0C"
"tcc": {
"name": "FET Temp",
"value": "47.6",
"unit": "\u00b0C"
"tcc2": {
"name": "PCB Temp",
"value": "49.2",
"unit": "\u00b0C"
"pout": {
"name": "Output Power",
"value": "400",
"unit": "W"
"vout": {
"name": "Output Voltage",
"value": "27.2",
"unit": "V"
"iout": {
"name": "Output Current",
"value": "14.6",
"unit": "A"
"vpv": {
"name": "PV Voltage",
"value": "101.1",
"unit": "V"
"ipv": {
"name": "PV Current",
"value": "4.1",
"unit": "A"
"whizbtemp": {
"name": "WhizBangJr Shunt Temperature",
"value": 28,
"unit": "\u00b0C"
"ibat": {
"name": "WhizBangJr Current",
"value": "0.0",
"unit": "A"
"soc": {
"name": "State of Charge",
"value": "99",
"unit": "%"
"battahrem": {
"name": "Remaining battery capacity",
"value": "199",
"unit": "Ah"
"battah": {
"name": "Battery capacity",
"value": "200",
"unit": "Ah"
"iabsbat": {
"name": "Battery Current Abs",
"value": "0.0",
"unit": "A"
"ichgbat": {
"name": "Battery Current Charge",
"value": "0.0",
"unit": "A"
"idisbat": {
"name": "Battery Current Discharge",
"value": "0.0",
"unit": "A"
"batstate": {
"name": "Battery Current State",
"value": "Discharging",
"unit": ""
"iload": {
"name": "Load Current",
"value": "14.6",
"unit": "A"
"pload": {
"name": "Load Power",
"value": "397.1",
"unit": "W"
"eff": {
"name": "Efficiency",
"value": "104",
"unit": "%"
From it I need to define the sensors with proper units and friendly names, is it possible ?
