I want to pass in a previously defined custom component as an argument to a constructor for a custom binary sensor.
The concept is to pass in a pointer to the custom component so the custom binary sensor can access one of its methods.
When I attempt to do so, I get a compile error in the lambda for the custom binary sensor. Which seems to indicate that the incorrect object type is being passed in. How do I access the previously defined object pointer for the custom component at the time the binary sensor is defined?
These are the lambdas for the custom component and custom binary sensor:
# Clock display component
custom_component:
- lambda: |-
XY_Clock *xy_clock_display = new XY_Clock(id(sntp_time), id(ds1307_time), id(bus_a));
return {xy_clock_display};
components:
- id: xy_clock_display
binary_sensor:
- platform: custom
lambda: |-
auto hwclock_comm_fail_binary_sensor = new HWClockCommFailBinarySensor(id(xy_clock_display));
App.register_component(hwclock_comm_fail_binary_sensor);
return {hwclock_comm_fail_binary_sensor};
binary_sensors:
name: "HW Clock Comm Fail"
This is the compile error I’m getting:
xy_clock.yaml:77:78: error: invalid conversion from 'esphome::Component*' to 'XY_Clock*' [-fpermissive]
In file included from src/main.cpp:34:
src/xy_clock.h:271:41: note: initializing argument 1 of 'HWClockCommFailBinarySensor::HWClockCommFailBinarySensor(XY_Clock*)'
271 | HWClockCommFailBinarySensor(XY_Clock *xyc) : PollingComponent(15000) {
*** [.pioenvs/xy-clock/src/main.cpp.o] Error 1
This is the code generated in main.cpp for the custom components:
// custom_component:
// lambda: !lambda |-
// XY_Clock *xy_clock_display = new XY_Clock(id(sntp_time), id(ds1307_time), id(bus_a));
// return {xy_clock_display};
// components:
// - id: xy_clock_display
// id: custom_component_customcomponentconstructor
custom_component::CustomComponentConstructor custom_component_customcomponentconstructor = custom_component::CustomComponentConstructor([=]() -> std::vector<Component *> {
#line 68 "xy_clock.yaml"
XY_Clock *xy_clock_display = new XY_Clock(sntp_time, ds1307_time, bus_a);
xy_clock_display = custom_component_customcomponentconstructor.get_component(0);
xy_clock_display->set_component_source("custom_component");
App.register_component(xy_clock_display);
// binary_sensor.custom:
// platform: custom
// auto hwclock_comm_fail_binary_sensor = new HWClockCommFailBinarySensor(id(xy_clock_display));
// App.register_component(hwclock_comm_fail_binary_sensor);
// return {hwclock_comm_fail_binary_sensor};
// binary_sensors:
// - name: HW Clock Comm Fail
// disabled_by_default: false
// id: binary_sensor_binarysensor
// id: custom_custombinarysensorconstructor
custom::CustomBinarySensorConstructor custom_custombinarysensorconstructor = custom::CustomBinarySensorConstructor([=]() -> std::vector<binary_sensor::BinarySensor *> {
#line 77 "xy_clock.yaml"
auto hwclock_comm_fail_binary_sensor = new HWClockCommFailBinarySensor(xy_clock_display);
binary_sensor_binarysensor = custom_custombinarysensorconstructor.get_binary_sensor(0);
App.register_binary_sensor(binary_sensor_binarysensor);
binary_sensor_binarysensor->set_name("HW Clock Comm Fail");
binary_sensor_binarysensor->set_disabled_by_default(false);
// network:
// socket:
// implementation: lwip_tcp
// =========== AUTO GENERATED CODE END ============
App.setup();
