I have the Samsung Smart TV integration and I’m just trying to define a simple switch or maybe input_boolean that sends On or OFF (I’m actually just interested in OFF), with no additional automation.
The controls from the integration work, however I am not sure how to plug into that and send the off signal.
The same thing I am trying to achieve for the KODI integration.
Can you please point me in the right direction? I have searched for defining a simple switch but none seemed to be close to what I wanted.
You don’t need to. Just use the services that every media player has, I linked to them above. Your TV and Kodi will both be able to be controlled using these services.
I also use a Samsung TV and I just created a switch template that sends the commands to the TV. Have you installed the Samsung integration? If you did then you can use the state of the entities in the TV device to control the on/off state of your switch.
@tom_l this looks like it’s what I need, thank you very much. I’m a bit afraid to take control of the Home Dashboard just yet though because I’m so new at this, but obviously this is the way to go forward to truly unlock HA.
