Defining conversation template with custom variables provided to intent_scripts:
Hi all,
I would like to ask you for help with sentence and intent script configuration because I am little bit lost in documentation not able to find what I need.
I have a script for turning my climate on in given hvac_mode with given temperature (scripts.yaml):
set_climate_custom:
  alias: set_climate_custom
  variables:
    target_entity_id: '{{ entity_id }}'
    desired_temperature: '{{ temperature | default(state_attr(entity_id, ''temperature''))
    target_hvac_mode: '{{ hvac_mode | default(''auto'') }}'
  sequence:
  - service: climate.set_hvac_mode
      hvac_mode: '{{ target_hvac_mode }}'
      entity_id: '{{ target_entity_id }}'
  - service: climate.set_temperature
      temperature: '{{ desired_temperature }}'
  description: Nastavení klimatizace na požadovanou teplotu
  fields:
    entity_id:
      description: ID entity klimatizace, které se mají nastavit.
      example: climate.living_room
    temperature:
      description: Teplota, na kterou se má klimatizace nastavit.
      example: '22'
    hvac_mode:
      description: Požadovaný režim HVAC. Pokud není zadán, použije se 'auto'.
      example: auto
  icon: mdi:air-conditioner
This script is perfectly working.
Now I am trying to define conversation and intent_script in configuration.yaml which would trigger this script and simply confirmed it was performed. Something like:
conversation:
  intents:
    SetClimate:
      - "Nastav klimatizaci {name} na {temperature} a režim {hvac_mode}"
  lists:
    hvac_mode:
      values:
        - in: "vypnuto"
          out: "off"
        - in: "auto"
          out: "auto"
        - in: "chlazení"
          out: "cool"
        - in: "topení"
          out: "heat"
intent_script:
  SetClimate:
    speech:
      text: >
       Nastavuji {{ entity_id }} na teplotu {{ temperature }} a režimem HVAC {{ hvac_mode }}.
      - service: script.set_climate_custom
          entity_id: "{{ entity_id }}"
          temperature: "{{ temperature }}"
          hvac_mode: "{{ hvac_mode }}"
I know this is wrong configuration.
Is it possible to do it somehow in configuration.yaml? How?
OK, since OpenAI conversation is able to run scripts, this is no longer needed.
I have just added system message part to be sure it will use the correct script (not necessary):
To control climate device use script set_climate_custom
