Defining states in scene
Hi folks,
I have created 5 scenes for my bedroom.
I have created automations to launch these scenes.
And I am looking for modifying rules in order to create a condition based on the current scene.
Basically I want to create a little state machine:
If I press on button 1
If scene=1
scene=2
If scene=2
scene=3
I then would like to define a scene sensor and define a state to this sensor in the scene code
I will then use this state as a condition and also to display the current scene in the UI
If my logic is correct I am a bit stuck as a newbie to implement it.
Many thanks in advance for your kind help
Best
Gael
Ok I was a bit in a hurry posting… newbie mistake :slight_smile:
For other newbies, here is how I did:
In my automation.yaml, I define an input select like:
input_select:
  chambre_scene:
    options:
       - scene1
       - scene2
       - scene3
Then I added after each scene in the scene.yaml
input_select.chambre_scene: sceneXX
and finally in my automations I was able to select as input_select.chambre_scene
In addition, a Selection Frame as appear.
Lesson learned for the newbies:
  1. Read the FAQ of the forum
  2. Search the forum (which is actually written in the FAQ)
