clemon79
(Chris Lemon)
December 10, 2016, 2:53am
1
Now that it’s no longer third-party, I’m trying to get the Harmony stuff set up to replace the functionality I was originally doing with HarmonyHubControl.
Basically this was stupidly simple: execute a script, issue a Harmony command; just a single remote button press. But the current documentation doesn’t really go beyond “here’s how to set up your activity list.” Can someone give me an idea of what the sequence would look like? I have…
mute_htpc_2:
sequence:
- service: remote.send_command
entity_id: remote.freds_harmony_hub
device: 34450182
command: Mute
…and I’m sure that isn’t right, but it’s probably close? Maybe?
Can someone help?
EDIT: Holy crap, that WORKS. Okay, so I think I’m good!
dax333
January 11, 2017, 3:53pm
2
Does anyone have example code of a switch for say controlling just the device power on the tv?
data_template:
command: PowerOn
device: 37313947
entity_id: remote.livingroom
I used to do it this way with another product.
- platform: command_line
switches:
vizio_tv:
command_on: "/config/harmony/HarmonyHubControl HarMony hub 10.0.1.16 issue_device_command 37313947 PowerOn"
command_off: "/config/harmony/HarmonyHubControl HarMony hub 10.0.1.16 issue_device_command 37313947 PowerOff"
clemon79
(Chris Lemon)
January 11, 2017, 4:15pm
3
So I put all of my switches in a single file, but this would give you an idea of the syntax:
sleep_htpc:
sequence:
device: 34450182
command: PowerToggle
dax333
January 12, 2017, 11:30pm
5
I can’t seem to get the syntax right. My switches are all in a separate file as well.
switches:
LivingRoom_Screen:
value_template: "{{ is_state('switch.source', 'on') }}"
turn_on:
device: 37313947
command: PowerOn
turn_off:
device: 37313947
command: PowerOff
dax333
January 13, 2017, 12:56am
6
Learned that caps are not acceptable
switches:
livingroom_screen:
Getting closer. Just have to fix the switch status being unavailable… Probably something to do with the value_template
