Delay action with a passed variable from event
Hey You! Thank you for reading this :grinning:
The code at the end of this post is an event that i am passing to an automation. I need to get the values from “event_response” to pass them in an Delay action. When i try:
delay:
seconds: ‘{{ event_response|float }}’
I get an error:
Error rendering Küche Steckdosen ResponseDauer delay template: UndefinedError: 'event_response' is undefined
also tried things like:
seconds:‘{{ event_response }}’
‘00:00:’{{ event_response }}’
The event_response_type contents are used to trigger the automation and they work… So how i can get this 3 from the event_response, so the Delay action understands the number in seconds?
    "event_type": "alexa_actionable_notification",
    "data": {
        "event_id": "actionable_notification_kucheon",
        "event_response": 3,
        "event_response_type": "ResponseDuration"
What value do you get when you paste
in to Developer Tools / Template ?
Thank you very much for your time :slight_smile:
I got undefined… or None
The event listener gets the data from the event alexa_actionable_notification (from there have i pasted the code)
The big question is:
What is the right template to use for the event_response data from the event named alexa_actionable_notification.
Because as i understand giving the variable '{{ event_response }}' in any template in actions got undefined.
I have searched for a template in Actions that gets data from events as variables but no luck…
I don’t have an answer for you, but pasting the entire automation might give more context to others who might :wink:
You have spend some time to read, think, and try to help me…
… so thank you very much sir!
The automation looks like that:
  - event_data:
      event_id: actionable_notification_kucheon
      event_response_type: ResponseDuration
    event_type: alexa_actionable_notification
    platform: event
  condition: []
  - delay:
      seconds: ''{{ event_response }}''
Try
seconds: '{{trigger.event.data.event_response}}'
From thread here:
YES SIR!
Now i understand how it works… I also found the trigger.event.data but i putted also the name of the event and i got again undefined…
So… trigger.event.data looks into the data that triggered this automation and pulls out the value from the variable next to it…
Thank you and have a wonderful day :smiley:
It worked ?
Yes it worked…!
I got +1 level in Home Assistant programming from your answer :wink:
:rofl:
Nice !
I got +1 from your question :stuck_out_tongue_winking_eye:
