Good day
I would like the code to do the following:
Switch on relay 4 when movement is detected - Working
Switch Off Relay 4 when movement is detected again - No Idea how
Switch Off Relay 4 after 5min regardless of any movement.
automation 1:
alias: Night Light
platform: state
entity_id: binary_sensor.spare_room_pir_sensor
state: "on"
service: homeassistant.turn_on
entity_id: switch.relay_4
Please supply me with the correct code for this automation
I have created a file called night_light.yaml in a folder called automations.
I have also created a folder called scripts with a file called night_light.yaml.
Here is the night_light.yaml file contents under automation folder:
alias: Night Light
platform: state
state: "on"
service: script.turn_on
entity_id: script.night_light```
Here is the night_light.yaml file contents under script folder:
``` night_light:
alias: Night Light
sequence:
- alias: Night Light On
- delay:
minutes: 5
- alias: Turn Night Light Off
service: homeassistant.turn_off
entity_id: switch.relay_4```
I have also added this line in the scripts.yaml file:
```- !include scripts/night_light.yaml```
And this line under the automation.yaml file.
```- !include automation/mode/night_light.yaml```
