Delay between HA and MQTT
I have a docker setup, with HA and the Toke/Mosquitto MQTT. This has been working great for a long time, but now im in trouble. The issue is that there now is a small delay between when a message arrives at the MQTT broker, and when its delivered into HA. The delay is not consequent but is in average about 1 second. This is a huge problem for me as I have a lot of lightswithes connected, where the timing between the on and off is important.
When connecting a MQTT client to the broker, the messages are instant, so its only when going into HA.¨
mqtt:
broker: 127.0.0.1
port: 1883
client_id: home-assistant
protocol: 3.1.1
username: xxx
password: xxx
The setup is running on a never Synology NAS
Do anyone have a similar issue?
@VDRainer does
Needless to say, I’m giving this release a miss.
Filed an issue on this.
Thank you
I roled back, and its working now
Fixed in 0.64.1 :grinning:
@VDRainer Great job with your debugging this issue on GitHub.
Have just updated to 0.64.1, testing when getting home from work
Thank you
