I have a GIRIER Tuya ZigBee 3.0 Switch Module (TS0002_switch_module
) installed on a wall switch that controls a light bulb.
I set up an automation on HA so when the switch state changes I turn on another light that is connected to a sonoff zbmini. The light that is connected to the sonoff zbmini turns on faster that the one connected directly to the TS0002. I’m talking on something around 100ms but it is a little annoying.
Since there isn’t a sonoff zbmini with 2 outputs do you recommend me another 2 output zigbee device to try? I would like something identical to sonoff zbmini where I can’t notice the delay between the input and the action.
Thank you
