Good day everyone, a Node-Red expert here (and a HA dummy )
I have an environment of 20 water pumps , that i have created a node-red dashboard for:
-Settings for the output per minute per pump
-Tank size configuration
-Recipes management
-etc
And i made a function that calculates for how long a pump should be on to output the desired amount.
The pumps are connected to a relay board , and the ESP32 (nodemcu-32s) is controling the relays.
I tried this with MQTT over node-Red , but it is not reliable because MQTT messages arrive late, and sometimes its ±30 seconds(all the pumps are started at the same time).
So after thinking i decided a way to go is to somehow push the time amount integer to esp32 , and let it do the delay itself, and then reply back.
So i want to have a custom topic for every pump(not a problem) but how can i use the received payload as an delay amount? I figured out how to switch on/off after then: function.
This is what i have so fa:
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: 'XXXXXX'
password: 'XXXXXXX'
ap:
ssid: "Test Fallback Hotspot"
password: "hXymJXBhjiVu"
ota:
password: 'XXXXXXXX'
logger:
level: DEBUG
mqtt:
broker: 192.168.1.103
username: admin
password: admin
discovery: True
on_message:
- topic: some/topic
then:
- switch.turn_on: pump1
- delay: !lambda 'return payload ms;'
- switch.turn_off: pump1
switch:
- platform: gpio
pin: 13
inverted: yes
This is not a solution, i am aware of that. but while searching the esphome docs i haven`t been able to find anything that i could benefit from.
