Delay done: false?
Howdo.
Scenario:
I have an automation I’ve been using for a while to help keep tabs on the state of charge for our car. It runs each night at 2300hrs, looks at the vehicle location and battery percentage, and reports back if there’s anything we need to do overnight. This works perfectly.
Keeping the polling sensor open on the car means that we do get some vampire drain, so I tend to turn it off if I know the car is sat unused. My problem is that the nightly automation then can’t see the car info, so I risk missing scenarios where a prompt would trigger.
I was solving this by using another automation, running ahead of the primary automation at 2230hrs, and checking to see if the polling sensor is off. If that condition is met, the automation turns the polling sensor on, waits for 35 minutes (so that the battery check can run with updated data at 2300) and then flips it back off again.
End result: Polling is always available for the period I want to check, and my preference to have it on or off is honoured.
Issue:
My automation does not turn the polling sensor back off. When I look at the trace, the delay seems to fail to complete. Sharing the steps below, can anyone see what I’m doing wrong?
Step 1: OK. Automation runs at 2230
Step 2: OK. Automation checks the polling sensor and continues
Step 3: OK. Automation sets the polling sensor
Step 4: Problem. Automation waits for 35 minutes
I note that the ‘done’ value is false. The syntax looks correct, as its correctly understood 35 minutes is 2100 seconds.
Step 5: Automation should turn off the sensor, but doesn’t reach this step
Per above, this step is not executed. There’s no condition on it, just that the delay never seems to complete.
Yaml:
alias: 2230 - Poll car if off, to update location
description: ''
  - platform: time
    at: '22:30'
condition:
  - condition: device
    type: is_off
    device_id: 7c1b76042f84538e96e8a82aa7a81ad8
    entity_id: switch.silent_bob_update_switch
    domain: switch
  - type: turn_on
    domain: switch
  - delay:
      hours: 0
      minutes: 35
      seconds: 0
      milliseconds: 0
  - type: turn_off
    domain: switch
mode: single
Thoughts
  • I realise I could add a third automation that turns the polling sensor off, but then I’d need another helper entity to say whether or not it was originally enabled, and this seems a long way round.
  • I don’t think its a UTC thing, my timezone is currently one hour ahead of UTC, so the delay doesn’t cross the date terminator in local or zulu.
  • I’m stuck for a reason why that delay isn’t passing execution to step 5. Are delays known to be a bit flaky? Am I doing something wrong? Is my approach just out?
Cheers for any light you can shed on this.
Same here: the delay should be 15 Mins but does not trigger…
Here’s the traces step result:
(Looking at the trace at 10:22:32)
Ausgeführt: 15. August 2024 um 10:00:18
Ergebnis:
delay: 900
done: false
This is the relevant part of the automation:
  - choose:
      - conditions:
          - condition: and
            conditions:
              - condition: numeric_state
                entity_id: sensor.tagesdurchschnittstemperatur
                above: 15
                below: 20
                entity_id: sensor.regenmenge_stunde
                below: 2
                entity_id: input_number.regenmenge_24h
                below: 10
                entity_id: input_number.regenmenge_7_tage
                below: 100
        sequence:
          - data:
              title: Rasensprinkler gestartet
              message: Der Garten wird für 15 Minuten bewässert.
            action: notify.mobile_app_huhuuu
          - data:
            action: notify.mobile_app_spatz
          - entity_id: switch.gartensprinkler
            action: switch.turn_on
          - delay: "00:15:00"
            action: switch.turn_off
Anyone has an idea?
:frowning:
Did you save the automation during the delay?
It’s better to create a new trigger when switch has been on for 15 minutes and then switch off.
Delaying automations is never a good idea.
