Both delays are working correctly. When triggered, after 5 seconds a picture will be taken and after 5 more seconds the picture will be send.
When I put an extra action before the first delay, this delay will be skipped. The picture is taken immediately after triggering:
In this case a light is turned on but I can use any action, the delay will be skipped. I know in older versions a delay was skipped when the trigger triggered again while the delay was counting. That is not the case. I can put the actions into a script but I would like to understand why this isn’t working.
I don’t have an instance to check on right now but your automation looks correct to me.
It has mode: single
so any subsequent triggers, whist it is running, should be ignored.
This ‘should’ work as you intend it to.
Try extending the delays and putting an input number increment inbetween steps with a timestamp sent to a notification to debug or similar.
Edit:
It’s faily easy to set a ‘notification’ but other options are discussed here : -
Thanks for your answer. Using the input number was a great idea (is used actually input datetime). The problem seems to be the camera. Besides the input-datetime I used a stopwatch in front of the camera so I could see the moment the picture was taken. Although HA triggers the camera at the right moment I get a photo from some seconds earlier. I suspect the camera of taking pictures every 10 (?) seconds and when you trigger the camera to take a picture you will get the last picture the camera made. So when I trigger at moment t I can get a picture from t-4s or t-5s or…
Maybe I have to configure the camera on a different way.
