Delay_off gives eror in binary sensor template
I have a binary sensor that combines input form two MQTT sensors and returns ‘on’ when either one is triggered. I want to add an delay_off, but this give me an error when checking the config and reloading.
commenting out the delay_off statement fixes the issue.
This is the relevant part of the configuration file:
binary_sensor
    sensors:
      woonkamer_movement:
        friendly_name: "woonkamer beweging"
        delay_off:
          minutes: 5
        entity_id:
          -  binary_sensor.woonkamer_beweging_microwave
          -  binary_sensor.woonkamer_beweging_pir
        device_class: motion
        value_template: >-
          {{ is_state('binary_sensor.woonkamer_beweging_pir', 'on') or
          is_state('binary_sensor.woonkamer_beweging_microwave', 'on')
here is the message from the log file
2017-12-10 11:16:03 ERROR (MainThread) [homeassistant.config] Invalid config for [binary_sensor.template]: [delay_off] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->woonkamer_movement->delay_off. (See ?, line ?). Please check the docs at https://home-assistant.io/components/binary_sensor.template/
and this is the check_config error i get
Failed config
  binary_sensor.template:
    platform: template
    sensors: [source /home/homeassistant/.homeassistant/configuration.yaml:134]
      woonkamer_movement: [source /home/homeassistant/.homeassistant/configuration.yaml:135]
        delay_off: [source /home/homeassistant/.homeassistant/configuration.yaml:137]
          minutes: 5
        entity_id: [source /home/homeassistant/.homeassistant/configuration.yaml:139]
        friendly_name: woonkamer beweging
        value_template: {{ is_state('binary_sensor.woonkamer_beweging_pir', 'on') or  is_state('binary_sensor.woonkamer_beweging_microwave', 'on')  }}
Successful config (partial)
please help me to formulate the delay_off correctly
Maybe try it with just the value template :-
binary_sensor
    sensors:
      woonkamer_movement:
        delay_off:
          minutes: 5
        value_template: >-
ok, I just gave that a try and unfortunately it does not work.
even tried with only the simplest value template but no dice there either;
the relevant code:
binary_sensor:
  - platform: mqtt
    name: woonkamer beweging pir
    state_topic: "home/woonkamer/boekenkast/sensor/pir"
    sensors:
      woonkamer_movement:
        delay_off:
          minutes: 5
        value_template: >-
          {{ is_state('binary_sensor.woonkamer_beweging_pir', 'on') }}
Error message:
2017-12-11 17:23:00 ERROR (MainThread) [homeassistant.config] Invalid config for [binary_sensor.template]: [delay_off] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->woonkamer_movement->delay_off. (See ?, line ?). Please check the docs at https://home-assistant.io/components/binary_sensor.template/
I tried it with delay_off: ‘00:00:05’ in one of my sensors and came up with the same thing, it just doesn’t work :frowning:
Different error tho’
in “/home/pi/.homeassistant/binary_sensors.yaml”, line 5, column 7
expected , but found ‘’
in “/home/pi/.homeassistant/binary_sensors.yaml”, line 6, column 9
OK, tried it like yours and it went thru’ no problem…
  sensors:
    kitchen_miners9:
      friendly_name: "Kitchen MinerS9"
      delay_off:
        minutes: 5
      value_template: >-
        {{ states('sensor.kitchenantminers9power')|float < 900.00 }}
From states table…
