Delay when reading sensor from Ecobee thermostat
I have a sensor reading the operation" status from my Ecobee3 thermostat. It seems the value is delayed a few minutes.
Ex: states.climate.home.attributes.operation is “idle”
I push the temperature up a few degrees.
heat kicks on within a few seconds
…still 'idle"
a few minutes later it changes to “heat”
heat turns off when desired temp reached
…value still reads “heat”
a few minutes later, value updates to “idle”
Any ideas?
Actually there’s another thread about this here;
can you post your info to that thread so we can close this one and consolidate everything? We are trying to gather some info top see if we need to post an issue to Github.
Thanks!
Done, this can be closed.
