Hi together.
I could need some advice about controlling my covers integrated via cover_time_based_sync.
Everything works fine including positioning control.
The issue I am facing is a delay of the cover to react. State changes take about 1 sec. delay to move the covers. This leads to incorrect positions if I move the shutter partially.
Since I just started using esphome after migrating from Tasmota, I am still learning a lot about esphome, so help would be highly appreciated.
Here is the template:
- platform: cover_time_based_synced
devices:
my_room_cover_time_based:
travelling_time_up: 47
travelling_time_down: 47
close_switch_entity_id: switch.dachrollos_kuche_ab
open_switch_entity_id: switch.dachrollos_kuche_auf
send_stop_at_ends: True #optional
aliases: #optional
- Dachrollo Küche
my_room_cover_time_based2:
name: Dachrollo Esszimmer
close_switch_entity_id: switch.dachrollos_esszimmer_ab
open_switch_entity_id: switch.dachrollos_esszimmer_auf
aliases: #optional
- Dachrollo Esszimmer
And this is esphome config:
esphome:
friendly_name: Dachrollos
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
use_address: 192.168.178.47
ap:
ssid: "Dachrollos"
password: ""
captive_portal:
switch:
- platform: gpio
pin:
number: D1
inverted: true
- platform: gpio
pin:
number: D2
inverted: true
- platform: gpio
pin:
number: D3
inverted: true
- platform: gpio
pin:
number: D5
inverted: true
- platform: gpio
pin:
number: D6
inverted: true
- platform: gpio
pin:
number: D7
inverted: true
Big thank you in advance,
Markus
