Delay with z-wave roller shutter controller
I’m starting my smart home and decided to use Z-wave for lights and shutters.
I bought a few roller shutter controllers from Wenzhou tz75 and from fibaro fgr222.
At first i bought few from Wenzhou but then i noticed that i get timeouts when i press up stop down without waiting (kind of a stress test).
I installed the fibaro and it worked smoothly up down stop…
that this means that i need to replace all the Wenzhou modules?
is there any wait to fix this?
I’m using latest Hassio with Aeotec ZW090 Z-Stick Gen5 EU as a controller.
here is part of the z-wave log
node44 is fibaro
node 19 is wenzhou
2018-11-04 19:00:55.403 Info, Node044, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2018-11-04 19:00:55.403 Info, Node044, SwitchBinary::Set - Setting node 44 to On
2018-11-04 19:00:55.404 Info, Node044, Sending (Send) message (Callback ID=0x47, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=44): 0x01, 0x0a, 0x00, 0x13, 0x2c, 0x03, 0x25, 0x01, 0xff, 0x25, 0x47, 0x70
2018-11-04 19:00:55.480 Info, Node044, Request RTT 74 Average Request RTT 50
2018-11-04 19:00:55.480 Info, Node044, Sending (Send) message (Callback ID=0x48, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=44): 0x01, 0x09, 0x00, 0x13, 0x2c, 0x02, 0x25, 0x02, 0x25, 0x48, 0x81
2018-11-04 19:00:55.516 Info, Node044, Response RTT 35 Average Response RTT 36
2018-11-04 19:00:55.516 Info, Node044, Received SwitchBinary report from node 44: level=Off
2018-11-04 19:00:55.564 Info, Node044, Request RTT 83 Average Request RTT 66
2018-11-04 19:00:55.565 Info, Node044, Response RTT 84 Average Response RTT 60
2018-11-04 19:00:55.565 Info, Node044, Received SwitchBinary report from node 44: level=Off
2018-11-04 19:00:56.572 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=109.1W
2018-11-04 19:01:00.282 Info, Node044, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Open - 1 - 1 - false
2018-11-04 19:01:00.283 Info, Node044, SwitchMultilevel::StopLevelChange - Stopping the level change
2018-11-04 19:01:00.284 Info, Node044, Sending (Send) message (Callback ID=0x49, Expected Reply=0x13) - SwitchMultilevelCmd_StopLevelChange (Node=44): 0x01, 0x09, 0x00, 0x13, 0x2c, 0x02, 0x26, 0x05, 0x25, 0x49, 0x84
2018-11-04 19:01:00.309 Info, Node044, Request RTT 25 Average Request RTT 45
2018-11-04 19:01:00.317 Info, Node044, Sending (Send) message (Callback ID=0x4a, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=44): 0x01, 0x09, 0x00, 0x13, 0x2c, 0x02, 0x25, 0x02, 0x25, 0x4a, 0x83
2018-11-04 19:01:00.343 Info, Node044, Request RTT 25 Average Request RTT 35
2018-11-04 19:01:00.353 Info, Node044, Response RTT 35 Average Response RTT 47
2018-11-04 19:01:00.353 Info, Node044, Received SwitchBinary report from node 44: level=On
2018-11-04 19:01:00.410 Info, Node044, Sending (Send) message (Callback ID=0x4b, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=44): 0x01, 0x09, 0x00, 0x13, 0x2c, 0x02, 0x26, 0x02, 0x25, 0x4b, 0x81
2018-11-04 19:01:00.435 Info, Node044, Request RTT 25 Average Request RTT 30
2018-11-04 19:01:00.445 Info, Node044, Response RTT 35 Average Response RTT 41
2018-11-04 19:01:00.445 Info, Node044, Received SwitchMultiLevel report: level=16
2018-11-04 19:01:00.493 Info, Node044, Sending (Send) message (Callback ID=0x4c, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=44): 0x01, 0x09, 0x00, 0x13, 0x2c, 0x02, 0x31, 0x04, 0x25, 0x4c, 0x97
2018-11-04 19:01:00.518 Info, Node044, Request RTT 25 Average Request RTT 27
2018-11-04 19:01:00.530 Info, Node044, Response RTT 36 Average Response RTT 38
2018-11-04 19:01:00.530 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=108.9W
2018-11-04 19:01:00.581 Info, Node044, Sending (Send) message (Callback ID=0x4d, Expected Reply=0x04) - MeterCmd_Get (Node=44): 0x01, 0x0a, 0x00, 0x13, 0x2c, 0x03, 0x32, 0x01, 0x00, 0x25, 0x4d, 0x92
2018-11-04 19:01:00.607 Info, Node044, Request RTT 26 Average Request RTT 26
2018-11-04 19:01:00.619 Info, Node044, Response RTT 37 Average Response RTT 37
2018-11-04 19:01:00.619 Info, Node044, Received Meter report from node 44: Energy=0.00kWh
2018-11-04 19:01:00.746 Info, Node044, Sending (Send) message (Callback ID=0x4e, Expected Reply=0x04) - MeterCmd_Get (Node=44): 0x01, 0x0a, 0x00, 0x13, 0x2c, 0x03, 0x32, 0x01, 0x10, 0x25, 0x4e, 0x81
2018-11-04 19:01:00.772 Info, Node044, Request RTT 25 Average Request RTT 25
2018-11-04 19:01:00.783 Info, Node044, Response RTT 36 Average Response RTT 36
2018-11-04 19:01:00.784 Info, Node044, Received Meter report from node 44: Power=108.9W
2018-11-04 19:01:01.390 Info, Node044, Received SwitchMultiLevel report: level=19
2018-11-04 19:01:01.439 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=0.0W
2018-11-04 19:01:02.076 Info, Node044, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Close - 2 - 1 - true
2018-11-04 19:01:02.077 Info, Node044, SwitchMultilevel::StartLevelChange - Starting a level change
2018-11-04 19:01:02.077 Info, Node044,   Direction:          Down
2018-11-04 19:01:02.077 Info, Node044,   Ignore Start Level: True
2018-11-04 19:01:02.077 Info, Node044,   Start Level:        0
2018-11-04 19:01:02.077 Info, Node044, Sending (Send) message (Callback ID=0x4f, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=44): 0x01, 0x0b, 0x00, 0x13, 0x2c, 0x04, 0x26, 0x04, 0x60, 0x00, 0x25, 0x4f, 0xe7
2018-11-04 19:01:02.173 Info, Node044, Request RTT 95 Average Request RTT 60
2018-11-04 19:01:03.223 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=108.7W
2018-11-04 19:01:07.363 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=62.9W
2018-11-04 19:01:09.103 Info, Node044, Received SwitchMultiLevel report: level=0
2018-11-04 19:01:09.147 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=0.0W
2018-11-04 19:01:14.084 Info, Node044, Received SwitchMultiLevel report: level=0
2018-11-04 19:01:14.129 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=0.0W
2018-11-04 19:01:15.792 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=108.8W
2018-11-04 19:01:20.143 Info, Node044, Received SwitchMultiLevel report: level=17
2018-11-04 19:01:20.190 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=0.0W
2018-11-04 19:01:47.077 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=108.1W
2018-11-04 19:01:49.122 Info, Node044, Received SwitchMultiLevel report: level=26
2018-11-04 19:01:49.168 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=0.0W
2018-11-04 19:02:47.910 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=108.8W
2018-11-04 19:02:50.695 Info, Node044, Received SwitchMultiLevel report: level=37
2018-11-04 19:02:50.742 Info, Node044, Received SensorMultiLevel report from node 44, instance 1, Power: value=0.0W
2018-11-04 19:04:42.085 Info, Node019, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Bright - 1 - 1 - true
2018-11-04 19:04:42.085 Info, Node019, SwitchMultilevel::StartLevelChange - Starting a level change
2018-11-04 19:04:42.085 Info, Node019,   Direction:          Up
2018-11-04 19:04:42.085 Info, Node019,   Ignore Start Level: True
2018-11-04 19:04:42.085 Info, Node019,   Start Level:        0
2018-11-04 19:04:42.086 Info, Node019, Sending (Send) message (Callback ID=0x50, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=19): 0x01, 0x0b, 0x00, 0x13, 0x13, 0x04, 0x26, 0x04, 0x20, 0x00, 0x25, 0x50, 0x87
2018-11-04 19:04:42.111 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:43.153 Info, Node019, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Bright - 1 - 1 - false
2018-11-04 19:04:43.153 Info, Node019, SwitchMultilevel::StopLevelChange - Stopping the level change
2018-11-04 19:04:43.154 Info, Node019, Sending (Send) message (Callback ID=0x51, Expected Reply=0x13) - SwitchMultilevelCmd_StopLevelChange (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x05, 0x25, 0x51, 0xa3
2018-11-04 19:04:43.179 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:43.189 Info, Node019, Sending (Send) message (Callback ID=0x52, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x25, 0x02, 0x25, 0x52, 0xa4
2018-11-04 19:04:43.205 Info, Node019, Response RTT 16 Average Response RTT 26
2018-11-04 19:04:43.205 Info, Node019, Received SwitchMultiLevel report: level=39
2018-11-04 19:04:43.251 Info, Node019, Request RTT 62 Average Request RTT 43
2018-11-04 19:04:43.253 Info, Node019, Response RTT 64 Average Response RTT 45
2018-11-04 19:04:43.253 Info, Node019, Received Meter report from node 19: Power=0.0W
2018-11-04 19:04:44.763 Info, Node019, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dim - 2 - 1 - true
2018-11-04 19:04:44.763 Info, Node019, SwitchMultilevel::StartLevelChange - Starting a level change
2018-11-04 19:04:44.763 Info, Node019,   Direction:          Down
2018-11-04 19:04:44.763 Info, Node019,   Ignore Start Level: True
2018-11-04 19:04:44.764 Info, Node019,   Start Level:        0
2018-11-04 19:04:53.189 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-04 19:04:53.201 Info, Node019, Sending (Send) message (Callback ID=0x53, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0x53, 0xa6
2018-11-04 19:04:53.226 Info, Node019, Request RTT 24 Average Request RTT 33
2018-11-04 19:04:53.237 Info, Node019, Response RTT 35 Average Response RTT 40
2018-11-04 19:04:53.237 Info, Node019, Received SwitchMultiLevel report: level=39
2018-11-04 19:04:53.281 Info, Node019, Sending (Send) message (Callback ID=0x54, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x00, 0x25, 0x54, 0xb4
2018-11-04 19:04:53.306 Info, Node019, Request RTT 24 Average Request RTT 28
2018-11-04 19:04:53.319 Info, Node019, Response RTT 37 Average Response RTT 38
2018-11-04 19:04:53.320 Info, Node019, Received Meter report from node 19: Energy=0.036kWh
2018-11-04 19:04:53.430 Info, Node019, Sending (Send) message (Callback ID=0x55, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x10, 0x25, 0x55, 0xa5
2018-11-04 19:04:53.455 Info, Node019, Request RTT 23 Average Request RTT 25
2018-11-04 19:04:53.467 Info, Node019, Response RTT 36 Average Response RTT 37
2018-11-04 19:04:53.468 Info, Node019, Received Meter report from node 19: Power=0.0W
2018-11-04 19:04:53.600 Info, Node019, Sending (Send) message (Callback ID=0x56, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x20, 0x25, 0x56, 0x96
2018-11-04 19:04:53.633 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:53.645 Info, Node019, Response RTT 36 Average Response RTT 36
2018-11-04 19:04:53.645 Info, Node019, Received Meter report from node 19: Voltage=227.5V
2018-11-04 19:04:53.754 Info, Node019, Sending (Send) message (Callback ID=0x57, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x28, 0x25, 0x57, 0x9f
2018-11-04 19:04:54.338 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:54.350 Info, Node019, Response RTT 36 Average Response RTT 36
2018-11-04 19:04:54.356 Info, Node019, Received Meter report from node 19: Current=0.000A
2018-11-04 19:04:54.464 Info, Node019, Sending (Send) message (Callback ID=0x58, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x30, 0x25, 0x58, 0x88
2018-11-04 19:04:54.488 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:54.502 Info, Node019, Response RTT 37 Average Response RTT 36
2018-11-04 19:04:54.502 Info, Node019, Received Meter report from node 19: Power Factor=0.00Power Factor
2018-11-04 19:04:54.648 Info, Node019, Sending (Send) message (Callback ID=0x59, Expected Reply=0x13) - SwitchMultilevelCmd_StartLevelChange (Node=19): 0x01, 0x0b, 0x00, 0x13, 0x13, 0x04, 0x26, 0x04, 0x60, 0x00, 0x25, 0x59, 0xce
2018-11-04 19:04:54.673 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:57.631 Info, Node019, Received Meter report from node 19: Power=296.1W
2018-11-04 19:04:59.522 Info, Node019, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Bright - 1 - 1 - false
2018-11-04 19:04:59.523 Info, Node019, SwitchMultilevel::StopLevelChange - Stopping the level change
2018-11-04 19:04:59.524 Info, Node019, Sending (Send) message (Callback ID=0x5a, Expected Reply=0x13) - SwitchMultilevelCmd_StopLevelChange (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x05, 0x25, 0x5a, 0xa8
2018-11-04 19:04:59.548 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:04:59.549 Info, Node019, Sending (Send) message (Callback ID=0x5b, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x25, 0x02, 0x25, 0x5b, 0xad
2018-11-04 19:04:59.625 Info, Node019, Request RTT 75 Average Request RTT 49
2018-11-04 19:04:59.637 Info, Node019, Response RTT 87 Average Response RTT 61
2018-11-04 19:04:59.637 Info, Node019, Received SwitchMultiLevel report: level=18
2018-11-04 19:04:59.688 Info, Node019, Response RTT 138 Average Response RTT 99
2018-11-04 19:04:59.688 Info, Node019, Received Meter report from node 19: Power=0.0W
2018-11-04 19:05:09.549 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-04 19:05:09.561 Info, Node019, Sending (Send) message (Callback ID=0x5c, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x26, 0x02, 0x25, 0x5c, 0xa9
2018-11-04 19:05:09.585 Info, Node019, Request RTT 24 Average Request RTT 36
2018-11-04 19:05:09.597 Info, Node019, Response RTT 35 Average Response RTT 67
2018-11-04 19:05:09.597 Info, Node019, Received SwitchMultiLevel report: level=18
2018-11-04 19:05:09.643 Info, Node019, Received Meter report from node 19: Power=0.0W
2018-11-04 19:05:09.770 Info, Node019, Sending (Send) message (Callback ID=0x5d, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x00, 0x25, 0x5d, 0xbd
2018-11-04 19:05:09.795 Info, Node019, Request RTT 24 Average Request RTT 30
2018-11-04 19:05:09.808 Info, Node019, Response RTT 37 Average Response RTT 52
2018-11-04 19:05:09.816 Info, Node019, Received Meter report from node 19: Energy=0.036kWh
2018-11-04 19:05:09.944 Info, Node019, Sending (Send) message (Callback ID=0x5e, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x10, 0x25, 0x5e, 0xae
2018-11-04 19:05:09.968 Info, Node019, Request RTT 24 Average Request RTT 27
2018-11-04 19:05:09.983 Info, Node019, Response RTT 38 Average Response RTT 45
2018-11-04 19:05:09.983 Info, Node019, Received Meter report from node 19: Power=0.0W
2018-11-04 19:05:10.044 Info, Node019, Sending (Send) message (Callback ID=0x5f, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x20, 0x25, 0x5f, 0x9f
2018-11-04 19:05:10.075 Info, Node019, Request RTT 30 Average Request RTT 28
2018-11-04 19:05:10.084 Info, Node019, Response RTT 39 Average Response RTT 42
2018-11-04 19:05:10.084 Info, Node019, Received Meter report from node 19: Voltage=227.2V
2018-11-04 19:05:10.132 Info, Node019, Sending (Send) message (Callback ID=0x60, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x28, 0x25, 0x60, 0xa8
2018-11-04 19:05:10.156 Info, Node019, Request RTT 23 Average Request RTT 25
2018-11-04 19:05:10.169 Info, Node019, Response RTT 36 Average Response RTT 39
2018-11-04 19:05:10.169 Info, Node019, Received Meter report from node 19: Current=0.000A
2018-11-04 19:05:10.221 Info, Node019, Sending (Send) message (Callback ID=0x61, Expected Reply=0x04) - MeterCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x32, 0x01, 0x30, 0x25, 0x61, 0xb1
2018-11-04 19:05:10.245 Info, Node019, Request RTT 24 Average Request RTT 24
2018-11-04 19:05:10.257 Info, Node019, Response RTT 36 Average Response RTT 37
2018-11-04 19:05:10.257 Info, Node019, Received Meter report from node 19: Power Factor=0.00Power Factor
I also bought a TZ75 and I notice a ~2 to ~7 seconds delay between an order and the execution.
Worst: the close action is not available even when the shutter is open
Never mind. I forgot to do the calibration process. (doc: http://www.tkbhome.com/upimg/file/1202353430132.pdf)
Working like a charm now. And no delay.
yes the calibration should fix this.
tell me please if you start and stop and start and stop there is no delay?
what Z-wave adapter are you using?
I also found these cheap controllers on aliexpress, but i’ve also seen that some people have problems with them on OpenHab.
Some questions: Is the positioning working? (e.g. can you set 50% to set the shutters only to half open)
And if you use the tz75 controller with the S1 and S2 buttons, does it automatically update the Value in Hassio?
the answer for both is yes
