Hi i tried searching but i dont think im using the correct key words.
I am new, just bought a HA Yellow, but have everything set up as it was previously so ive done pretty well tbh, using the wizard, although I have looked at YAML and sort of see how it works.
I have one request though, I have a simple motion detected outside light with a hue motion sensor, and its a bit sensitive even on the lowest settings and just pointing down to the floor, so i thought making it only trigger the light after 2 seconds of movement would help, but im at a loss on how to do that using the wizard.
Adding a condition of the motion sensor with a duration of 2 secs just stops it working.
Both answers are the same basically.
It’s just a delay of two seconds.
For as far as I know the (hue) sensor always has a delay before returning to clear. So it’s not that a one second motion results in the sensor only giving a “motion on” for 1 second. I think it’s around 10 seconds
One cannot say to the sensor, when you see movement, you dont see it for two seconds.
