Delete Auto-discovered device
I have seen multiple topics around it in the forum but I still don’t get it.
How do I delete an auto-discovered device?
In my case I am using the Tradfri integration. I removed a bulb from Tradfri Hub.
Now I would like to delete it from Home Assistant. What’s the right way to do it?
Thank you
Go to configuration / entities, find your entity, click it. Click the delete button in the pop-up card.
Hi tom,
removing the entities removes the device only from lovelace, it’s still visible under “devices” tab.
You will have to delete the integration.
So I’ll have to delete the integration every time I remove a device :-/ ?
