Hi there
is there a way to delete deactivated devices from HA? I really want to get rid of them as some of the entitites still pops up. Any suggested approach to remove them from HA??
Thanks - JJ
Hi there
Thanks - JJ
Thanks, will try. I have a couple of mobile phones (device trackers) which I do not follow any longer. Deleting the whole integration is not a way as there are other devices with the same integration (FritxBox) which I still need. regards JJ
Hi there,
so those entities where the devices are deactivated, could NOT be removed as decribed above. And as the integration has several entities which I do NOT want to remove, deleting the integration is not a way to proceed.
Therefore still wonder if there is no way to delete unwanted/deactivated devices. Could nearly believe, that this shoudl not be possible in HA. Thanks - JJ
It helps if you use the correct description of your problem. Devices are collections of entities. Are you really talking about devices or are you talking about single entities?
Did you disable them manually?
If so, enable them first, then delete them.
