Hi all!
Long story short, i have a flow that dyamically creates entities based on some information from an API.
Is there a way i can make this same flow delete these entities – or atleast delete a specific entity ?
Hi all!
Long story short, not enough info to answer this.
What if I shortened it to “Can I delete a HA entity from a NodeRed flow via API or some other way” ?
That’s clear .
I think you must find an answer for that without the node red part…
I found:
Via the node red entity nodes you can create specific entity’s:
But these are only the ones you can create/delete with this code. Not all entities…
Thanks! You certainly had better luck finding things than i did!
I am still struggling with this.
I have a node red flow that registers and updates sensors, using an API node
"type":"nodered/discovery",
"server_id": serverId,
"node_id": nodeId,
"component": "sensor",
"config": {
"name": name
Surelyt theres an easy way to “un-register” that sensor ?
