Occasionally one of my sensors sends bad data - it’s a wind speed sensor and it sends 1000 m/s.
I’ve been deleting the data using SQLite Web. Originally I did something like
DELETE FROM “states” WHERE entity_id=sensor.weather_wind_speed AND state > ‘100’;
This, obviously failed when the DB chanced to using metadata_id as the identifier. So then I did
DELETE FROM “states” WHERE metadata_id=‘76’ AND state > ‘100’ ;
I got the metadata_id by looking in the correct table. That failed recently because it looks like all the metadata_id changed. So now I do
SELECT * FROM “states_meta” where entity_id=“sensor.weather_wind_speed”
to get the metadata_id and then use that in the DELETE command.
I feel there must be a better way of doing this. Any suggestions?
Some background if it is relevant: the data comes in via MQTT with this config
- name: “Weather Wind Speed”
unique_id: weather_wind_speed
state_topic: “enviro/weather”
value_template: “{{ value_json.readings.wind_speed | float }}”
device_class: “wind_speed”
unit_of_measurement: ‘m/s’
icon: “mdi:weather-windy”
My install is fully updated.
