I would take a hunch that you could get a list of files using something like
Personally, because my HA is running on a virtual machine, and all the files I care about are actually on the (windows) host, I’d use something like a batch file to generate the output I need, and pipe it to a text file, then read that into HA to process. I’ve done this before for other use cases.
If your HA configuration is sliced you most probably have a shell_commands.yaml where then you can add a new line (e.g. for removing old files from under /home/pi/logs) :
then in the automations directory create a new automation remove_old_files.yaml:
alias: "Remove old files"
initial_state: "on"
platform: time
at: "22:00:00"
- service: shell_command.remove_old_files
then restart HA and at 22:00 the automation will trigger the removal of old files.
The find comamnd above works the following way: it takes all files recursively below the configured directory (e.g. /home/pi/logs), will apply the filter -mtime +30 which selects only files whose modification time is older than 30 days and will execute the command provided by -exec, in the above case removal of those files. Without the -exec part it will simply list them.
For more information on find you may use man find in a terminal on your Pi.
Is there a way to check the folder size, and to delete them in blocks based on that?
For example, at 22:00:00 each night it will check to see if the folder has exceeded Xgb, and then to delete 1 day’s worth of data, and then continue looping around until the folder size get’s back to Xgb, so that rather than having 30 day’s worth of data you have Xgb (plus whatever was recorded before 22:00:00)?
I’m not sure that this can be done, but it might be useful to some people wanting to replicate the “keep until space is needed” function that traditional NVR have.
I think that this will likely do exactly what I’m looking for
size Indicates maximum folder size to be kept in Megabytes (value 0 disables this functionality). After checking last modification time additional check is made towards folder size. If it exceeds the specified value, then files are deleted even if specified time has not been exceeded. Files are deleted starting from the oldest file until the condition is met. It is an optional attribute.
