Delete groups.yaml from HA?
Is it possible to delete the groups.yaml from the config in HA if all I use is Lovelace?
It would clear up all the group view entities I have. Also with Areas now I would say there is no need for the groups right?
there are times when you might need to use groups apart from defining “views”. If you don’t have any groups besides “views” or groups that are only used in those views and don’t ever need other groups then you can probably get rid of it.
But it might just be better to delete all the view related groups from groups.yaml and leave the rest of the file intact.
Good point. For right now I have just commented the call for the group.yaml file in config. That way I can always go back.
