can you delete automations using the gui? rather than editing the yaml file?
you can manage your automation’s from the automation’s tab // look here : https://www.youtube.com/watch?v=0j_hWdCTip4
or use an web editor //
look here : https://github.com/danielperna84/hassio-addons
and here : Repository: HASS configurator
cheers hav started using configurator very cool.
Sorry. Can you describe how one can use the configurator in Hass.io to delete an automation.
Cheers.
I can not believe we still can not delete an automation within the GUI - WTF?
Same question. How do you delete an automation using the Automations Config tool?
Same problem, I do not see where to delete automations in the frontend seem to remove the automations after removing the related script from the automatons.yaml file though
Hi!
Please vote this up: Add option DELETE automations from frontend and hopefully this will be implemented
Best: Peter
