Delete old backups shell command error
I have a shell command to delete old backups that runs every night, right after I make my nightly backup.
The backup works but the deletion fails.
shell_command:
  delete_old_snapshots: find /backup/* -mtime +30 -exec rm {} \;
The error received is:
Error running command: `find /backup/* -mtime +30 -exec rm {} \;`, return code: 1
NoneType: None
I’m running hassio on a raspi 3. I can see backups older than 30 days in the SAMBA /backup/ share.
Any idea why this fails?
Also just FIY these backups are automaticly copied off the pi to a NAS in case of catastrophic sd card failure.
Try
find /backup/* -mtime +30 -delete
Thanks I’ll give it a go.
Same problem unfortunately:
2018-09-21 01:00:11 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: `find /backup/* -mtime +30 -delete`, return code: 1
And files older than 30 days are not deleted.
It’s not a secure as you might want but you could try
find /mnt/usbbackup/* -mtime +30 -execdir rm {} +
Why is it not secure?
If I understand correctly, if someone were to go the directory where the files are and create a “rm” shell script, and “.” was in your path, they could have it run whatever they wanted. It’s the typical linux caveat, if someone hacks into your system plants a malicious command somewhere, it could do damage. :slight_smile:
Thanks for the explanation. I’ll try the shell command tonight and see how it goes. Should it have a semi-colon (;) at the end?
I do not believe so, but it may depend on what linux shell you are using. Try it without it and see if it throws an error.
Hmm. Still no go.
Error running command: `find /mnt/usbbackup/* -mtime +30 -execdir rm {} +`, return code: 1
NoneType: None
No wonder. This is not where my backups are: mnt/usbbackup
Still cant get this to work.
Error running command: `find /backup/* -mtime +30 -execdir rm {} +`, return code: 1
NoneType: None
What does this return?
I don’t have SSH installed to try it. Will install it tomorrow and try. Very late here. Thanks for your help.
It finds one file.
core-ssh:/backup# find /backup/* -mtime +30
/backup/ca7bab03.tar
This is the only file older than 30 days in /backup (I had a clean out yesterday).
I’ve been trying this also and what I’ve found is that -execdir doesn’t work however -exec does work :slight_smile:
So mine looks like …
delete_old_snapshots: find /backup/* -mtime +10 -exec rm {} +
Very similar to my first post:
NoneType: None
I have noo idea what “+” does instead of “\;” but I’ll give it a go. Thanks.
From the help file…
-exec CMD ARG + Run CMD with {} replaced by list of file names
similar to what you were doing…
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
Is it not -30? I set this up on a Windows schedule yesterday…
if you use -ve number it takes the newest files :frowning:
core-ssh:/backup# find /backup/* -mtime -5
/backup/55f83d3e.tar
/backup/93282f30.tar
/backup/cd708564.tar
/backup/f510d046.tar
core-ssh:/backup# find /backup/* -mtime +5
/backup/0d00a7d8.tar
/backup/31238b08.tar
/backup/3c14e9d6.tar
/backup/3ea6fbd3.tar
/backup/a6f2844a.tar
/backup/b2f5c512.tar
/backup/b9336de2.tar
core-ssh:/backup# ls --full-time -t
total 742532
-rw-r--r--    1 root     root          8192 2018-09-24 23:29:17 +0100 f510d046.tar
-rw-r--r--    1 root     root         69632 2018-09-23 23:27:18 +0100 93282f30.tar
-rw-r--r--    1 root     root      96716800 2018-09-23 01:04:29 +0100 cd708564.tar
-rw-r--r--    1 root     root         24576 2018-09-20 23:26:59 +0100 55f83d3e.tar
-rw-r--r--    1 root     root      86650880 2018-09-19 23:06:03 +0100 ec7bfd29.tar
-rw-r--r--    1 root     root      64020480 2018-09-15 23:04:11 +0100 a6f2844a.tar
-rw-r--r--    1 root     root      77598720 2018-09-14 23:05:33 +0100 3c14e9d6.tar
-rw-r--r--    1 root     root      78172160 2018-09-13 23:05:08 +0100 b2f5c512.tar
-rw-r--r--    1 root     root     123033600 2018-09-12 23:07:15 +0100 0d00a7d8.tar
-rw-r--r--    1 root     root     101079040 2018-09-11 23:05:58 +0100 3ea6fbd3.tar
-rw-r--r--    1 root     root      75755520 2018-09-10 23:04:23 +0100 31238b08.tar
-rw-r--r--    1 root     root      57210880 2018-09-09 23:03:38 +0100 b9336de2.tar
Yeah ok… perhaps it’s different with the windows command I used… was just a thought.
In Windows I have this command:
ForFiles /p “C:\Users\david\Dropbox\Apps\Docker Backups NUC” /s /d -2 /c “cmd /c del @file
Where the /d -2 denotes files older than 2 days. It does exactly that and stops my dropbox filling up…
