Delete old backups shell command error
So I haven’t found a fix for the shell command, but I have adapted what the dropbox addon was doing and created a custom service to perform the clean up. In a few days I will provide a link to the code. I need to clean up the services as there is a few hard coded items that should be configurable.
I got some time and cleaned up the code today. The automation hasn’t ran yet, but I have manually called the service several times. Credit for majority of the code goes to the dropbox sync and @danielwelch .
I don’t understand what they mean host and token in configuration.yaml. what needs to be written there?
Host would be the url to your homeassistant (e.g.: http://hassio.local:8123/ it should include the port.) The token is a long lived access token.To create a long lived access token you would need to go to your account profile and click create token in the “Long-Lived Access Tokens” section of the page. I apologize for not providing those in the examples.
I have also since confirmed the automation is working. It’s been running on my setup for the past week without issues thus far.
Thank you for this! Works like a bomb!
Thanks heaps for this @junja430. Works perfectly.
looks really promising!
I have no idea what i am doing wrong… but it keeps giving me this error:
Component not found: clean_up_backups_service
I have downloaded the “raw” data into a notepad++ file and saved it as a .py file
I have put the clean_up_backups_service.py file in the root of the custom_component directory
I have multiple custom components and they are working fine
I have put the needed data into configuration.yaml:
clean_up_backups_service:
host: !secret http_base_url
token: !secret clean_up_token
number_of_backups_to_keep: 7
Can someone point me into the right direction?
Thank you!
Hmm. After updating to 0.91.0 the following automation is failing:
automations.yaml
- id: daily_snapshot_clean_up
  alias: Daily Snapshot Clean Up
    platform: time
    at: '04:00:00'
    - service: clean_up_backups_service.clean_up
configuration.yaml:
  host: !secret clean_up_base_url
  number_of_backups_to_keep: 20
With the following error in the log:
2019-04-06 04:00:05 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.daily_snapshot_clean_up. Unknown error for call_service at pos 1:
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 57, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6cd1dc10>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='[REDACTED].duckdns.org', port=443): Max retries exceeded with url: /api/hassio/snapshots (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6cd1dc10>: Failed to establish a new connection: [Errno -3] Try again'))
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/automation/__init__.py", line 380, in action
    await script_obj.async_run(variables, context)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/script.py", line 131, in async_run
    await self._handle_action(action, variables, context)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/script.py", line 210, in _handle_action
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/script.py", line 299, in _async_call_service
    context=context
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 88, in async_call_from_config
    domain, service_name, service_data, blocking=blocking, context=context)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1138, in async_call
    self._execute_service(handler, service_call))
  File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1162, in _execute_service
    await self._hass.async_add_executor_job(handler.func, service_call)
  File "/config/custom_components/clean_up_backups_service.py", line 66, in handle_clean_up
    snapshots = get_snapshots()
  File "/config/custom_components/clean_up_backups_service.py", line 38, in get_snapshots
    snapshot_info = requests.get(hassio_url + "snapshots", headers=headers)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='[REDACTED].duckdns.org', port=443): Max retries exceeded with url: /api/hassio/snapshots (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6cd1dc10>: Failed to establish a new connection: [Errno -3] Try again'))
The funny thing is if I trigger the automation manually (using the trigger option in the automation’s more info card) it works as expected (it deletes all but 20 snapshots).
I was planning on upgrading this weekend. I’ll take a look as soon as I upgrade and fix the code.
So I’m a little confused at the moment. I adjusted my trigger time on my automation and made sure it would delete at least one backup. Upon it’s execution I received no errors and it completed deleting the backup. Are you on .91 or .91.1? I upgraded to .91 to try
Also which version of hassos are you on I am on 1.12. You can see this by going to the hassio view and clicking on system.
I’m on HassOS 2.11 and HA v0.91.0.
I have changed nothing related to this (added a couple of cameras and restarted a few times) and it is working again.
EDIT: Failed again last night. Same error.
socket.gaierror: [Errno -3] seems to mean DNS resolution failure.
I’m using my DuckDNS address. I would try with the local one instead. But I have no certificate for https://10.1.1.100:8123 only the DuckDNS domain so I’m not sure if that will help.
Sorry for my delay in responding, I am not getting an error. I am looking into it tonight I’ll keep this thread updated as I have them.
Of course last night it all worked and no errors again. (facepalm). I’m scanning the logs now to find the error I saw a few days ago.
Quick update before we wait till my automation executes. I found a few things:
  1. When ever the error happened a call the my router for device tracking happened.
    1. I updated my polling interval in an effort to make this not happen.
  2. I have also adding more logging and increased the logging level of requests to gather more information as to what is going on.
Hopefully it will fail tonight and I can get some information. I have updated to the same hassos version as you as well. Thank you for your patience.
Thank you for looking into the problem.
It’s very strange that I can reliably trigger the cleanup automation manually (from the automation more info pop up) . It’s only the time triggered automation that fails.
I agree. I also haven’t had any issues when triggering this manually. I’m curious if the time you have the automation executing as well as myself is interfering with something that is a scheduled job on hassio. I have my automation set at 03:00 so i’m not far off from when your’s is executing.
I have updated the gist to use to have some error handling. I have also changed from requests to aiohttp and asyncio which is what home assistant is using. I’ve also used hassio’s loop which will hopefully allow it retry. I’ve run it once manually which was working but I’ll keep you posted about how it runs tonight.
I am also planning on updating to follow the new structure of home-assistant after I know it’s working.
Just a quick update. I am still getting the errors, I am still working through them I apologize for the delay in having a fix.
