I was tinkering with the vacuum template in the config and now i have these read only entities that I can’t delete. I can’t click the checkbox.
Most probably just refresh the page. There is some UI caching which shows non existing entites still for some time in some cases.
Thanks,
however it just disappeared after some restarts.
I have the same issues from a deleted/removed integration, that create many device.tracker entities…
They are still there and cannot be manually deleted after many HA restarts (Browser cache is also deleted)
How to remove those entities?
Anyone can pls help here?
I need it too.
Same issue. I updated to 2024.2 and now have the new proximity integration. I removed the proximity sensor definitions from my yaml config but they are still in my entity list. How do we clean this up?
You could use Frenck’s Spook tool https://spook.boo/ but be very careful (backup before you do anything!)
Creating a full backup and restore it helped for me.
