Delete sensors from Energy Dashboard
I have just reinstalled the Octopus Energy integration but I neglected to delete the old sensors from the energy dashboard first. I now have the following (see screenshot) with no obvious way of deleting the missing sensor. Anyone know how to do this?
Developer Tools → Statistics- > Fix Issue.
Hi this is not enough or far too long as you will have to erase each and every data .
Change the unit of your sensor .
Go to statistics … it will then propose either to change all the values with this new units or …… to erase all the values
Et voilà
Phil
No, the “fix issue” option should give them the option to delete the entity from the statistics data.
You are confusing this with the ramp icon used to edit the data.
You are right but this seems new as I am pretty sure this was not possible several months ago .
Good improvement
Phil
Thanks both for your help. That has certainly cleared the stats but hasn’t removed the assocoation of the missing sensor with the dashboard. See screenshot. Anyone got any further suggestions?
Hi
Did you try to use the dust bin icon ?
The sensor with the dustbin beside it is the new one I want to keep. The old one I want to delete doesn’t have a dustbin, hence my problem.
