Due to me messing up the snapshot creation (I started a full snapshot including the media folder, however, I forgot that I have a 5TB external HD mapped to it) I ended up with a bunch of used space that wasn’t supposed to be used.
That’s also what I am thinking and I am at a loss here. If you subtract the /media (external HD) from the total HA container it should only be using 1GB and not 30Gb.
Another useful piece of information that I will add to my first post: I am using HASIO default install. The only fancy thing I have is an external HD mounted at /media/HD.
I don’t think so, or I don’t know home. Using the web interface I can only SSH into the HA container and the temp folder is inside the supervisor container (I think, as I am not an expert in the Home Assistant OS).
What I did was follow this guide to get SSH access to the Host OS, then I went to the supervisor tmp folder
