Deleting a utility meter
Hi there,
I want to delete all data of a utility meter. I deleted the utility meter. Under Statistics automatically the warning “Entität hat keinen Zustand” appears. Now I can delete the long term statistics you can see in the screenshot.
screenshot
When I no create a new utility meter with the same name the statistics of the old utility meter appears. So they aren´t deleted. I rebooted HA several times.
Before that, I wanted to correct the value via statistics. This did not work either.
How can I solve the problem?
Best regards,
Michael
Long term statistics are not the same as recorder values. The long term statistics are removed using the repair, but I think you are looking at short term recorder history. That will disapear by itself once it is older than the maximum retention period and the periodical purge is executed.
