Dell WYSE dx0d, Home Assistant and Whisper
Dear Colleagues,
I have Home Assistant (Core 2024.12.5, Supervisor 2024.12.0) on Dell Wyse on ‘Linux Wyse 5.10.0-33-amd64 #1 SMP Debian 5.10.226-1 (2024-10-03) x86_64 GNU/Linux’ and Python 3.9.2 and on it I tried to use Whisper integration on it, but unfortunately without success.
After installing Whisper integration and trying to start it, the time is endless:
INFO: Service exited with code 256 (by signal 4)
WARNING: Your CPU does not support Advanced Vector Extensions (AVX). Whisper will run slower than normal.
I uninstalled it and tried to install the Faster Whisper integration from the AlexxIT/FasterWhisper custom repository in HACS.
Unfortunately, I also get an error here:
Failed to load configuration interface: 500 Internal Server Error Server got itself in trouble
and in the logs:
Unable to install package wyoming-faster-whisper==1.0.1: × No solution found when resolving dependencies: ╰─▶ Because only the following versions of ctranslate2 are available: ctranslate2<=3.17.0 ctranslate2==3.17.1 ctranslate2==3.18.0 ctranslate2==3.19.0 ctranslate2==3.20.0 ctranslate2==3.21.0 ctranslate2==3.22.0 ctranslate2==3.23.0 ctranslate2==3.24.0 ctranslate2>4 and ctranslate2>=3.17.0,<=3.24.0 has no wheels with a matching Python ABI tag, we can conclude that ctranslate2>=3.17.0,<3.17.1 cannot be used. And because wyoming-faster-whisper==1.0.1 depends on ctranslate2>=3.17,<4 and you require wyoming-faster-whisper==1.0.1, we can conclude that your requirements are unsatisfiable.
maybe someone of you has HA and managed to install Whisper or Fast Whisper, or knows how to install one of these integrations, then I would like instructions on how to do it.
The same :,(
