Delta Dore garage door problem
I installed Home Assistant with tydom2mqtt plugin. Connection is ok, my accessories are well recognized.
The blinds are recognized as shutters and the garage door as a button. However, only the blinds work correctly (open/close), the garage door doesn’t open or close when I press the switch though Home Assistant.
I can’t see what’s wrong in the logs.
Would you have any idea to help me configure the garage door correctly?
Thank you very much.
