I am trying to integrate deluge but having trouble. I have the daemon running on the default port on a windows PC. I have manually set deluge:deluge:10
in the auth config file to avoid any credential issues but it still wont connect and i don’t know why.
I don’t even know how to troubleshoot it as there doesn’t seem to be a way to manually connect to the deamon apart fomt he webui which connects fine. I have also made a new windows firewall rule to allow the default port to accept connections.
Any suggestions?
I get the following warning
2019-07-17 23:33:36 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform deluge
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/deluge/switch.py", line 40, in setup_platform
deluge_api.connect()
File "/usr/local/lib/python3.7/site-packages/deluge_client/client.py", line 78, in connect
self._connect()
File "/usr/local/lib/python3.7/site-packages/deluge_client/client.py", line 92, in _connect
self._socket.connect((self.host, self.port))
File "/usr/local/lib/python3.7/ssl.py", line 1150, in connect
self._real_connect(addr, False)
File "/usr/local/lib/python3.7/ssl.py", line 1137, in _real_connect
super().connect(addr)
socket.timeout: timed out
#Switch
- platform: deluge
host: 192.168.0.x
port: 58846
username: "deluge"
password: "deluge"
#Sensor
- platform: deluge
host: 192.168.0.x
port: 58846
username: "deluge"
password: "deluge"
monitored_variables:
- 'current_status'
- 'download_speed'
- 'upload_speed'
