Deluge Sensor Setup error
Hello, Im Trying to add my deluge download to the config. But Im getting an error message that it can’t connect to the host.
Here’s my setup:
  - platform: deluge
    host: !secret deluge_host
    urlbase: /deluge
    username: !secret delugeusername
    password: !secret delugepassword
    monitored_variables:
      - 'current_status'
      - 'download_speed'
      - 'upload_speed
Here’s the Log:
2018-02-05 13:39:55 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform deluge
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
    return fut.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/deluge.py", line 58, in setup_platform
    deluge_api.connect()
  File "/srv/homeassistant/lib/python3.5/site-packages/deluge_client/client.py", line 50, in connect
    self._socket.connect((self.host, self.port))
  File "/usr/lib/python3.5/ssl.py", line 1027, in connect
    self._real_connect(addr, False)
  File "/usr/lib/python3.5/ssl.py", line 1014, in _real_connect
    socket.connect(self, addr)
socket.gaierror: [Errno -2] Name or service not known
For the host name I’ve tried both the direct IP address 192.168.1.102 and the remote access URL https://(myhost).duckdns.org/deluge
I wasn’t sure if the urlbase line was needed, but It was required to setup my sonarr config, so I included it with the deluge config. I did try it without the “urlbase” and I get the same error.
Did you ever get this figured out? I am getting the exact same error and am also pretty sure that my config is correct.
