I have two instances of Home Assistant running on the same network:
Production server:
- Home Assistant Supervised (Ubuntu 18.04.4; Intel CPU laptop)
- Samba service installed in Ubuntu
- I can connect to its Samba share from either a Windows, MacOS, or Ubuntu machine.
Test server:
- Home Assistant (HassOS; RPI3B+)
- Samba Add-On installed
- I can connect to its Samba share only from Windows and MacOS machines but not from an Ubuntu machine.
In a nutshell, two out of the three operating systems allow me to connect to the Samba Add-On onthe Test server (and all three can connect to the Samba service on the Production server). Only the Ubuntu machine is denied connection to the Samba Add-On.
From the Ubuntu workstation, I am challenged to enter the password twice and then get this refusal:
I recall reading a thread where someone else encountered the same problem and their solution was to disable the Samba service on the Ubuntu machine. I haven’t tried it but, for my purposes, that’s an impractical workaround (because I also need to share files located on the Ubuntu machine).
The Samba Add-On’s configuration is straightforward. The only changes from the default is that I’ve supplied a password (it’s required).
workgroup: WORKGROUP
username: homeassistant
password: redacted
interface: ''
allow_hosts:
- 10.0.0.0/8
- 172.16.0.0/12
- 192.168.0.0/16
- 'fe80::/10'
veto_files:
- ._*
- .DS_Store
- Thumbs.db
- icon?
- .Trashes
compatibility_mode: false
I’ve tried using a different workgroup (TEST
) but it had no effect.
Can someone explain why connection attempts from the Ubuntu workstation are denied by the Samba Add-On?
EDIT
I overlooked to mention that I’m using the latest published version of Samba Add-On (9.2.0) and, interestingly, the log file shows no record of attempts to connect it from the Ubuntu machine.
The only record in the log is when I attempt to connect by supplying this:
smb://servername
instead of just clicking the server’s name in the Networks list. It still refuses the connection (reports that it could not get a list of shares) and the log indicates a netbios connect
attempt but doesn’t report it as an error.
