Denon AVR buttons
Hello BebeMischa,
Can you give me some advice?
Looking forward
config → dashboards → upper right corner 3dots → resources → lower right corner add resources
Add the /hacsfiles/ampli-panel-card/ampli-panel-card.js? In resources as javascript already but what to do then?
Should i create a new dashboard for it?
add both those:
- type: module
  url: /hacsfiles/ampli-panel-card/ampli-panel-card.js
- type: css
  url: /hacsfiles/ampli-panel-card/font.css
restart ha.
the you have to be able to add the card to your existing dashboard.
Maybe a bit stupid but, where should i add this?
the first half you already done. The second goes the same way, just choose stylesheet, when adding.
Done that now, but still got the
  • entity: media_player.marantz_sr6010
    type: ‘custom:ampli-panel-card’
    brand: Marantz
    info: AV Surround Receiver SR6010
    zone2: media_player.proiettore #(option)
No card type found
try:
type: custom:ampli-panel-card
No succes!
Have done:
Add repo in Hacs
Restart ha
Download and install the ampli-panel-card through Hacs
Restart ha
Add both js and css in resources as stylesheet.
Restart ha
Ampli-panel-card is not visible when trying to add this.
When try to add it by chosing manual i got No type card found.
Any tips
Then I’m out of knowledge… :frowning:
Hi BebeMischa,
Finally i found the solution!
I used
’ ampli-panel-card ’
Doesn’t work!
Then used
" ampli-panel-card "
And it works :thinking:
Looks very nice now.
Thanks for all your advice👍
Regards
Raspy The Netherlands.
Happy for you, it worked out, almost neighbor… Greets from A’dam :wink:
Don’t know if you like footbal…
Again no victory for us (XXX)
Greets from Z’dam :sunglasses:
No, not really, football is far away from my sight field (even when i live almost next to the Ajaxhole…)
But I love your cacao :wink:
Is it still possible to get a option button work in this ard?
So i can navigate the Blueotth Tansmitter and activate my BT Headset?
Hey!!
i’m also having issues with this custom card :(((
i did this but when I set an entity to it, the visual panel disappears!!! why??
When the entity is empty, it seems ok. so how does it get an entity name??
entity: ‘’
av_receiver_family: onkyo
brand: Onkyo
info: TX-NR696
auto_size: autosize
